Just thought id add, that when i go to the dragstrip, on sunday, when all the serious faster people are there, there are several imports that are turbocharged. the ones that are on a budget, do so with junkyard parts. about 4 of em there, had intercoolers from volvos, and used PVC pipe for the piping that goes to the intercooer and stuff. they painted it black, and i didnt notice. it must have worked well, because some of these little inline 6s and 4 bangers were runnin 12s. so, im sure if you got some pipe, cut it to fit, it would work just fine, and for a total of about 30 bucks, it would be cheaper than some muffler shop makin you pipes. Oh, and the pipe seemed to hold up fine on the guys car i was talkin too, no melting or nothin, and he had had it on there for about 15K miles. i think its not a question of wether or not the PVC pipe will work and be durable, but wether or not you like the look.
If you want some nice, shiny aluminum pipes, go to autozone, and buy some intake kits for a 2001 honda accord. : ) they are perfect as they are for a cold air MAF pipe, when you cut the angle different at the turbo end. im sure if you can weld aluminum, or use some aluminum brazing rods, then you could section off this pipe, and make up a nice custom made turbo to intercooer pipe perhaps. like those import guys do, make bends with welds. each pipe is aorund 65 to 69 bucks.
HTH
