PWR BRK current draw
bad V6
I have a current draw on the PWR BRK fuse circuit, 1987 GN with a Power Master. Unplugging the Power Master motor and brake switch make no difference in the test light hooked between the battery and the battery ground cable. Removing the PWR BRK fuse eliminates the current draw. Can anyone tell me what else is on that particular cicuit? Or does anyone have a schematic of that circuit?
Thanks,
Pat
Coolant Fan Delay Relay..... unplug that and see if it kills the draw.... it's the closest to the windshield of the three on the DS fenderwell, known for failure and running the battery down, and not necessary for proper fan function..... just unplug it and tape it off. it's in the same circuit/off the same fuse....PWR BRK :)
