The right side hangs a little lower, thats mainly because of the upper control arm\spring clearance. (Completely stock suspension.) All that needs to be done is a little mod to the tail pipe hanger on the rear frame rail...hope this helps...Mike
Greg thank you. I have the Hooker with the Aeochambers and I am very happy with it. Unfortunately it rusted out by both mufflers and I need to replace it. Really want to keep the look and sound I have now. My system uses a straight back left offset muffler with the right side having a dimple on it (opposite on passenger side). The Pypes uses a center offset muffler at an angle so I am trying to weigh my options.
I have the GN1 and it sounds great! Only issue I have with it is that it will drone the f$&k out of you on long drives at certain rpms. I just recently picked up the Pypes system and will be trying it at some point
