Q on C4HD brakes on g body/b body spindle
BOOSTEDGNs
my question is whats the difference in the use of b body over g body spindle?
is it the alignment part of this conversion?
Can I use the g body spindle with the adjustable control arms to make this thing work?
Or should I use the B body Spindles?
Either way Ive got the 1LE brake conversion with ub arms Im not using and would be going to adjustable control arms for handling aspect of it.
please anyone and everyone in the know Ive searched the forums and have not found the answer that Im after and wondered if I could hear it straight from a source that is in the know......
thanks in advance and any insight to my question
Alan
The B Body spindles have a signifigant increase in bump steer compared to the G Body Spindles.
Using the fully adjustable (double) upper A-Arms allows for running more caster, which at high speeds helps to keep the car tracking straighter.
So Bruce what your saying is that to reuse the g body spindle and work off that....just want to be clear in my head before i sort out through the pile that Ive collected and put all the pieces Im gonna put to use in one corner...
Last q just one more whats your opinion on
g body spindle
c4HD 13" brakes w/ cust bracket
kore alum hub for short/cut down hub off thirdgen...for $80
does this sound right? please excuse me for being repetitive
do I cut the same way as b body spindle, just hack the ears off my g body spindle?
doesnt anyone make something to rotate the steering rack to accomodate the b body spindles?
On my mustang thats what someone did make custom poly bushings offset for this purpose....
thanks alot for your time
Alan
Alan
There is no rack on a GN, its a recirculating ball quadrant and sector system.
g body spindle
Yes, use the G-Body Spindle.
13s are more then enough.
Dunno Kore, I just had a stock rotor cut down to use as a hub, for the rotor.
Nothing like that, is on the GNs, ie Rack and pinion.
oke thanks alot guys for your input on this subject
that goes to show me I should be more observant of my gn that means I dont spend enough time wrenching my cars as I used to must be laziness/age.
and Im only 33 :eek:
Alan
g body spindle it is....cant wait to get started..
you could go with s-10 extreme front spindles with dual piston calipers
i did this on my regal . got them on ebay from s-10 warehouse for 250
