QA1 Coil over shocks/springs
Woody
I am strongly considering installing a QA1 set up from UMI because I have lowered my 87 GN with Bell Tech spindles and the ride is a little soft for my taste.........I like the ride height and don't want to increase it with new stock springs.....What is the difference in the
big block and small block set up UMI sells....I am inclined to go with the big block springs for a stiffer ride. Anyone on the board have a coilover suspension on your G body?
Thanks guys,
Woody
I just put a set on the front with 2" spindles. The small/big block difference is the spring rate. But with the qa1's you can adjust the shocks to be stiff or soft for you, all the spring is to do is support the weight of the vehicle.
Call Mark at SC&C (www.scandc.com) he will tell you everything you need to know and more. Ask him about the varishocks. They're what I went with. better shock and they have a huge selection of spring rates instead of just 2.
