i was having problems with the secondaries sticking closed on my quadrajet. It on a v6 turbo motor. the motoring was idling at about 4000 rpm. i turned off the engine and it back fired hard. i was out in the dunes and before i got back to camp, it back fired a couple of more times. after i got the secondary sticking problem fixed and the idle working correctly, it now would stumble and backfire as i revved the motor. while driving, if i revved it slowly through the rpm's it seems to run fine but if there is any kind of load, such as going up a hill, it bogs down with no power. it also does it just revving it from idle. does anyone have any suggestions for fixing the problem?
