Six_Silver
- Sep 10, 2003
I bought 2 brand new steel main caps and had them fitted on a block with the stock front and rear caps. They align bored/honed these caps with ARP studs. Well it ends up that the block has to go to .030 and I have .020 pistons. So instead of buying new pistons I want to bore my std block to .020 and use that block instead of the block I just had the aline bore done on.
So, can I use the steel main caps that were just aline bored on the std block and have them aline HONE this block? Reason I ask is that I dont want to spend another 250 on an aline BORE if they were just done. Shouldnt the bore be the same size on these new caps as they are on the front and rear stockers from the other block? Wouldnt an aline HONE clean them up enough to use?
Machinists/builders please respond.
