cottonpicker14
- Feb 17, 2005
Hi. my fuel pressure was set around 45 lbs on a stock TTA and my BL lean number was reading 151 at idle at operating temperature. I have changed all my hoses.
I dont have my own fuel pressure guage, but today I started the car, warmed it up and turned the screw in (clockwise) on the adjustable fuel regulator. I turned it about 2 full turns and as I turned it my BL number started to drop from 151 down to 137.
Since I dont know what my pressure is now, (will order a guage tomorrow) I was wondering that since I turned the screw inward I assume I am dropping the pressure.
Since the BL came down with lower fuel pressure, what would be the minimum pressure I should run (vacuum hose off) before its too low ? Seems my BL number is tied to a low fuel pressure but I dont want to have to little pressure and destroy the engine.
