cottonpicker14
- Feb 17, 2005
I did a search about moisture and methanol and that it loses it potencey if moisture gets in and to make sure the storage container is sealed. Does Denatured also have the same problem with moisture ?
Reason I ask, is I am currrently using denatured and am considering going over to Methanol. I only go through about a gallon of denatured a month.
Question is, if Methanol was sitting in the reservoir of the car for the month, isnt it prone to collect moisture since the top of Razors reservoir is vented ?
Also, would denatured have the same problem ? Reason for asking is that I dont want to change over to Menthanol if its more prone to collect moisture than Denatured if it sat in my reservoir since I dont drive it regularly.
