Question On Balancing Engine ?????
PHANTASM
POWERED BY POVERTY
do i need to re-balance my engine if i change the front hub and flywheel from a different engine.
this is for an 87' 109 engine, stock crank.
i lost the original front hub and flywheel. i am doing a different block for the internals.
any help appreciated.
If it is all stock stuff, then I believe that all the stock hubs and flex plates should work
-I AM NOT AN EXPERT and I am not building or even seen your situation so be sure your self.
Oh boy, that was some help - huh :p
No you should be fine as long as the new parts are not damaged and they never removed weight from those parts on the original balance job. Frank
