10-4 I already did...I tryed listening to the motor for the humm..to see if it was still working because the PM fuse blew(Brake light is on steady ever since). My hearing is not that good, I even had my hearing aids on. I think the PM motor's working. Anyways replaced the fuse after that I felt the motor with my hand, it was warm. I'm going to try a new brake switch, I'm not going to bother replacing the fluid inless the brake light goes off. Afterwards yeah for sure I'II flush out the fluid. If the switch doesn't fix the problem, my guess the motor/pump maybe is no good
