I'd like the car to run cooler. I put in a 160 t-stat a few weeks ago and started using the SM this weekend.
In general, when cruising, the car is in the high-170's to low-180's. In traffic, or after whacking on it a few times, the temps climb to the high-180's to mid-190's. I've noticed that the fan is rarely kicking on when this happens.
Is the fan set to kick on the low setting at a certain temp...and if so...what is it? What triggers the high speed relay? When I shut the car off, the fan will kick on after a minute or two and run for a few minutes. Why wouldn't my fan run when the car is running and has reached the aforementioned temps? I just replaced the fan relay. Will a chip change when the fan kicks on? Can I just hardwire the fan to run when the motor is running?
Thanks.
S.
Thanks.
S.
