Here it goes......
One is I found recently that my torque convertor is a lock-up and did not have a chance why its not locking up. Should I leave it the way it is or locking it up really helps.
Second that I got a new sets of MT ET drags 26x10's mounted on a 15x8 Weld's. I had been getting good luck with 14.5-15lbs of air in the tires and air bags at 25lbs on the right and 0-1 lbs on the left. The best 60ft I could get was a 1.88 and a 7psi launch. Also note that no tubes and screws on the rims with no slippage on the tire. Suspension is stock with bilstein shocks.
