Jul 27, 2016 #1 D Dhos1 Self-tuning wanna-be Joined Apr 14, 2012 Messages 1,484 Which way should the power steering filter face in the return line. The flow arrow goes towards the hydroboost setup or towards the steering box???
Jul 27, 2016 #2 T turboclam Well-Known Member Joined Sep 30, 2003 Messages 2,109 Is it a high or low psi filter? Butch sells the high psi ones.
Jul 27, 2016 #3 D Dhos1 Self-tuning wanna-be Joined Apr 14, 2012 Messages 1,484 Clam i brought it from oreillys
Jul 27, 2016 #4 D Dhos1 Self-tuning wanna-be Joined Apr 14, 2012 Messages 1,484 Clam i brought it from oreillys Attachments 1469670932685563212275.jpg 2 MB · Views: 92
Jul 27, 2016 #5 T turboclam Well-Known Member Joined Sep 30, 2003 Messages 2,109 I imagine you could put it between the steering box and reservoir, pointing toward the reservoir.
Jul 28, 2016 #6 TURBOELKY Well-Known Member Joined Jun 27, 2005 Messages 3,474 That's likely for the return line because the rest are high pressure lines. In that case, flow would be from the hydroboost unit to the return (reservoir). Install on the low pressure return line, flow going to reservoir.
