SignUp Now!For a system that works but is apparently low on freon (R12) due to a possible leak is it best to convert to 134? What is involved and what would the cost be?
Where do you get it?I use Enviro-Safe ES-12a which is a drop in replacement for R12. It is also more efficient then R12 and requires less to fill the system.
RemoveBeforeFlight
You can purchase it but as far as I know it is illegal to use in the United States in a r12 system
That is illegal. Doubt anybody has been prosecuted but converting to 134a with the intention of converting to a hydrocarbon refrigerant is illegal.
Also, I don't consider throwing fittings on a conversion.....
And for those that don't know ES-12a is a mixture of propane and butane and is highly flammable.
Crack a tank of 134a and hold a lighter to it. Do the same with ES-12a. But make sure your video taping so I can watch
Thinking about my last comment it sounded a little dickish. Here's the way I see it. Whether you agree or not, it is not an EPA approved refrigerant for use in a r12 system.
There are sythetic alternatives, there is still a lot of R12 out there, or you could convert to r134a correctly. I don't personally see the reason to use debatably dangerous and unapproved refrigerants
