race gate
crazygn
10's here i come
my brother is buying a 3"down pipe that does not use the ebow any more, but he does not have the cross over with the wastegate flange on it.
Question is , where can i weld a flange and put a race gate at.
thanks guys
my deltagate is welded onto my crossover on the driver's side right before it turns to go under the trans.if you plan on running the wastegate open you can put it there,but if you plan on running it to the exhaust(i would it's loud)i'd see about putting it on the passenger side.
later,sean
is there any where else they can go. or does it have to go on the cross over somewhere.
yes
yes there is one other way on the uppipe but that would look werid i think.
mine is on the crossover
brent
Mine's going on the uppipe to downpipe. I think it would look awesome in the right spot. Plus they get all dirty under the car and are usually the lowest spot so if you hit something the wastgate will most likely take a beating.
