I got a Racegate a few months back and had it rebuilt by Turbonetics. I just finally put it on and cannot get my boost controller to work. I can only adjust up or down about 3psi. I have an 11lb spring in it now and can only adjust between 14 and 17psi. It came back with a 7lb spring and then I could only adjust between 9 and 12psi. Another thing is that the area that I can adjust the boost is only about a 1/4 turn on the knob. Any more turns in either direction and nothing happens. I'm basically using a compressor regulator setup. I used to have a Deltagate connected to it and it worked perfectly. I double checked my hose connections and they are on correctly according to the diagram on gnttype.org. I'm using a Mease DP. What could be wrong? Should I double check my lines to make sure they are not plugged up? Could my regulator have gone bad, or maybe the Racegate was rebuilt wrong?
Thanks in advance for any help.
Mike
Mike
