Racegate turbonetic
GN280CI
I little question? the racegate turbonetic,to support really 900 HP or it has a limit :confused:
:D i try to perfect my english :D
Keep writing, it will get better... That wastegate is rated at 900 plus HP by turbonetics. I am still running one with my present turbo and have used it on a Turbonetics 88 turbo. I plan to upgrade soon to the New Gen wastegate by Turbonetics, it's rated at 1000 plus HP and is much larger than the Racegate.
hope that helps,
hope that helps,
:cool: ok thank jack :cool:
someone told me that a smaller gate will work fine with a big turbo and higher boost b/c ur only bleeding off a little bit of exhaust gas in trying to keep the boost high. any word on this jack? seems to make sense. in this case would a deltagate work with a 3 in dp and a 72Q?
hope that helps,
jack
Do you have the price for the new generation ? its the same boltage from the old racegate ?
