Racetronix New SS Teflon Fuel Line Kit #FLK-G7B1
hemi8
Goin Sideways
TurboBuick.Com Supporter!
This is a Brand New Kit, bought it but I decided not to install it (selling car). This will fit with the AN fittings if you have those type of fittings on your fuel pump sender (like the Racetronix twin fuel pump setup) or it will also work with the rubber hoses if you do not have the AN fittings on your sender. I have included the proper size fittings which will allow you to convert from AN to pipe fittings so your factory size hoses from your sender will connect right up. You get everything listed here
http://www.turbobuick.com/forums/threads/new-ss-teflon-fuel-lines-filter-and-fittings.399086/
plus the fitting I have explained. This is all brand new never opened. Racetronix suggested I list this item here to avoid restocking fees and because they are currently out of stock.
475.00 B/O
plus 15.00 shipping FedEx ground.
Paypal is fine
Mike
RETURNED, no longer available.
