racetronix plug and play and fuel pump
ok well I am getting power (for 2 seconds) to the pump connections so that is a load off my shoulders..
I will try to reinstall it again. I had the sock pointing towards the drivers side last time and don't have a lot of fuel in the tank. I have switched over the sock and will try to add more fuel this time (time to get the jerry can out)
It's working now..
The only thing I changed was moving the sock to face the passenger side. It could have been working fine before, maybe I just didn't give it enough chance..?? Plus what threw me off was the FP gauge I was using. It was registering 0 psi.. My last one had a nipple on it, I didn't realize that this one I had to remove the schrader valve to get a reading...DOH!
Hot wire kit was easy to install.
glad to see you finally got it in:D how did you wire the hotwire kit? any noticeable difference after dirving w/the new pump?
Thanks. Yeah I am glad to! :)
No difference whatsoever. I didn't really check my FP before under boost so I cannot compare.
Mentally there is a big difference though knowing that it's changed and ready to go.
