looking for some help. this spring on my 86 gn, the radiator fan would run after i turn off the engine for long periods of time. i knew the motor was that hot to run that often. i came this forum, to discover that a rely switch go bad and to unplug it. i down loaded a diagram showing where it was located. after that, no problem until last week came after work, parked and turn off and again fan running after i turn off the car. i waited a few minutes did not quit. i disconnected the battery. reconnected a few days later drove 3 miles and parked in the garage and again fan running after i turn off the car. i felt the rad cap and it was not hot. now what is causing the fan not turn off? any thoughts. thanks
