SignUp Now!3/4-16
Peter
PITA I had to weld an AN fitting on the original fittings, years ago.
I hope somebody comes up with an adapter.
I can get adapters, they are inverted flare EXPENSIVE!
Looking at $25 each plus shipping! Got a batch coming so I can put my oil cooler lines back on the site. These allow use of -8 braided hose. Pictures installed on my GN shows them capped off as I am not running the oil cooler right now. Ran the -8 hose for years without any issues. Just wanted to simplify the motor compartment a bit.
I would like to run -10 AN lines to my Alradco radiator. I would need -10 AN male to I believe 3/4-16 inverted flare. Are those available?I can make them if you guys want. Just need to know the details.
That sounds like it might work. Have you tried this? I wonder if a rubber o-ring would work best. I've seen some with a nylon ring.fwiw -08 AN thread size is 3/4-16 . although its not going to be a proper seal to the flare seat in the rad cooler a -08AN orb should screw right into the radiator and should seal with an oring or a doty seal and you can get -08ORB to 10an from summit
https://www.summitracing.com/parts/ear-at985009erl/overview/
