radiator trans cooler question..need an answer A.S.A.P
peterkin
..it isn't rocket science
I know i asked this question in the chatroom last night but i am still fuzzy about it.
How is the trans cooler lines in the radiator routed?
I was told that they were coiled up inside the end tank and not running through the radiator.
All of the "lines" are inside the end tank on the radiator.
These lines are referred to as the transmission cooler.
If your water level is down low enough you can see the cooler.
Gary
