When running an aux cooler
with the internal radiator cooler, I recommend mounting the cooler in the grill area. Behind a f/m intercooler is fine. The intercooler is not going to be hot all the time. Only under boost conditions, which shouldn't be for very long stretches.
I don't believe in mounting the cooler flat, out of the air stream and relying on a fan to take the place of the power of having the cooler in the direct airstream.
Another simple test. Pick whatever fan you wish. Put your hand in the airstream of that fan and note the power of the airflow. Now jump in the car and take a drive on the freeway. Lower the driver's window and put your hand out the window flat to the airstream. You'll be amazed.
