Little6pack
 - Jun 2, 2002
My GM daily driver has a power antenna located in trunk which is stuck in up position.
Every time I shut or turn my radio off. I hear the motor running trying to push up or pull down the antenna.
I want to disconnect this but have thought about putting in a manual antenna that I can put down when I go to car wash.
How or what would you use to connect the existing cable to the new antenna cable? DO THEY make some type of fitting that will join them?
