ramchargers 93 chip?
87GNcospg
Send your Donations
finally going to start doing upgrades to my 87 GN. i was looking at the chips on ramchargers.com
http://www.ramchargers.com/cgi-bin/...rfnbr=25470&cgmenbr=541&cat1=25468&cat2=25469
and was wondering if anyone has used the 93 octane chip? if i use a couple gallons of xylene once in a while will it make the chip go crazy? im new to installing chips into vehicles so im not qute sure about them. are there any other cips that are better?
just need some opinions.
I've use the Ramchargers 93 chip for stock and the Bosch 43 injectors.
It works fine.
I have used xylene in the tank to clean the crappy stock injectors and once to up the octane.
No problems running that chip and xylene with it.
When you run xylene as an octane booster you need to increase the boost for any performance gain assuming there is no knock with the 93 fuel.
