mayosmechanic
- Jun 16, 2003
Do I need to do anything special or just place my order?
Originally posted by Scott4DMny
How long before I can get my custom harness?
Originally posted by Bens87tr
So how does this control the fans differently from the way the Ramchargers harness works? If I remember correctly the RC setup runs the fans at full blast when it gets a signal. Now does this kit run high/low? If it dies then is there a way to have it run on high all the time? With my frontmount installed I need as much cooling as possible.
Originally posted by kyturbo
I'm in for one. What is the difference in the two products you show on your website? Also I am assuming the harness will work with a FAST system. Also would like to be able to manually turn on the fans with a switch.
I have a couple of questions specific to my application, what is the best way to contact you. I don't want to confuse any issues here. Thanks
Originally posted by gordyzx9r
What had to be done to the stock battery connectors to be able to do this?
Also, I use the old style Kenne-Bell hi/lo fan switch setup which gets wired to the ceramic resistor that's mounted on the stock fan assembly. What happens to this ceramic resistor when I install the Ramchargers Dual Fan with this Racetronix harness?
How do I keep the ability to use a hi/lo fan switch option?
Originally posted by Racetronix
The factory battery nuts push out from the front and the new ones go in their place. It takes a bit of force to get the new ones in but they do fit. Have them on my car NP. You will need to control the factory high and low speed relays to control the Racetronix harness. Jumping the resistor with a switch is kinda
Thanks, I think I got the idea for the battery.
As far as wiring the switch into the relays for the hi/lo control...how do I do that?
Thanks,
Gordy
Originally posted by HOTSIX
Ihave just rec'd a Ramchargers fan setup with GN adapter harness.
I looked at the pic of your kit but the plugins look too big.....Capsers kit leaves me with a male end to plug into the fan.
