NoMoreMustangs
- Oct 28, 2015
Yep that worked, thanks for that. Now the question becomes, how do you revert back to the relay
SignUp Now!So is this something that fails in the ecm?Get a hold of Bob Bailey aka (TurboBob). He's the man that can fix it. Have to send him the ECM.
For now you can drive the car with the jumper until you send off the ECM. The pump will only run with the key on.
Your Welcome and good luck.Have a good Christmas.
Rick
did you check the fuses? I think 2 wires are hot with key on at relay connector, then one goes to pump and the other goes to comp. I think the comp turns the ground on and off.
? Where do you live, on the Moon?Thanks for the continued replies. After jumping it so the pump always runs, I'm satisfied with it just staying like that until I get the new pump and regulator. Whenever it does get shipped... 7 weeks and counting.
