b4black
- May 24, 2001
I alwasy suspected that my downpipe could be hitting somethng abd causing false knock (a common problem on 86/87 cars). When I installed my Casper's knock gauge, it became even more clear, because I could see the LED's light up exactly when it shifted. I was changing my plugs the other day and I found that the stock downpipe was resting against the header/crossover flange. If I shook the DP at the bottom where it meets the converter, it would bang. There is VERY LITTLE room between the DP and the header/crossover.
I bought a 7½" turnbuckle with a hook and an eye (loop). I bolted th eye to the DP/converter lange and hooked it to the frame. I was able to pull the DP away from the header flange. It has cured almost all of the shift knock.
I have a polyurethane motor mount to install which should keep the motor from flopping around. That should take care of it all.
I would suspect that with the little amount of room for the DP and ~20 years, that most cars will have some problem with this.
