Razor install problems
Sydwyndr
Admin
Staff member
I am sure I have everything wired correctly. Tan to tan, green to green, gray to gray, low fuel(red), pwr inj(red), pump(red) all together to fuseable box +, pump(black), pwr inj(black) to fuseable box -. Fuseable box(red) to ign in fusebox, fuseable box (black) to ground. Now, when I turn on the ign switch I get the low level light on because there is no alky in the tank. When I turn blue knob to on the pump runs wide open and the pwr inj light is on full bright. Test button does nothing and where you set the blue dial does nothing either. What did I do wrong?? :confused: :confused:
The green wire is where the PAC senses boost pressure. Apply some voltage to it and the system will lite up like a christmas tree :biggrin: . Same can happen if the MAP loses ground.
Glad you figured it out ;)
