razors kit w/ max effort
N2HIPSI
1 of 463
Razor,
Check out my sig. I have run as fast as 119mph at 21lbs w/ no traction.(1.8's) I just ordered a complete rear suspension set-up including anti-roll bar from HR Parts. This should solve the 60 ft issues. I am running a max effort chip with a choice of 20 or 26 degrees timing. Will your system be any more difficult to tune with this set-up? I feel like the car has 10.70's in it at 25lbs of boost. Thanks,
Marley
Your MPH will be no issue on alky. Your ET quest.. if you get all your issues squared away, very possible to do.
So if you get your 60 foot taken care off, get your top end taken care off... get your chip's timing dialed in.. should be able to bust into the 10's. How far??? Thats a loaded question :D
The only issue is when you run lower timing, the car doesnt have as much burst as it does with high timing. So you need to get the 330 foot down.. the rest will fall into place. Maybe run an extra 1lb or two on the bottom to make up for the lack in timing.
Again it goes around tuning. And the 20 degree setting is what you'll probably start with.
