Razor's kit with ?
Not Avg 6
A buddy of mine has a Bad A$$ '34 Ford coupe all trick out with a GN motor i it. Problem is we don't have room under the hood for any intercooler so far. While daydreaming I though of using Razor's kit in place of the intercooler. We're not trying to run mega boost, we'll just see what we can get. What you guys think? Razor?
If you can keep the boost under 20 PSI.. it may work OK with alky. Past that it gets IFFY on temp.. and consumption...And you'll need to comeup with a solution for the reservoir for the alky.. you'll need to call me.. def not over an internet forum :)
Thanks, Razor. I had about a 20lb. limit in mind and we already thought about one of those custom billet reservoir tanks. Also, knew I could do it over the forum, just wanted to get your opinion first. My buddy isn't on the forum so I'll mention things to him tomorrow and go from there. :cool:
