1987
- Jan 30, 2010
Motor was built with the champion irons and cometic gaskets/ and head studs. The motor was never put in car or started on dyno, never heat cycled... It was decided to go with the champion aluminum heads now, so the question is can I reuse the cometic gaskets that have been torqued down but never run, also, the shop used copper coat on the gaskets when putting the motor together the first time, so that is another issue, the residual copper coat left over after pulling it back apart for the aluminums..
should i reuse the cometics, has anyone ever done this??
also, I understand that the studs are different for the aluminums? any suggestions on how to put the studs in the block, i.e. thread sealant on head ends, arp assembly lube on tightening end?
thanks for any input.
