BetMinesFaster
Turbo LSX Trader
- Aug 7, 2007
Just curious what to make of it?? reads anywhere from orange to red on the caspers gauge, just wondering where to go or what to look for? I have been chasing a knock problem with it for months already with no luck, its different every time, sometimes 13 or 14 ke, sometimes as little at .7?? No pattern except seems worse in 1-2 than the high gears, and seems to be less kr if you roll into it rather than stabbing it......any thoughts would be great, im not spraying the alky right now because im trying to get the tune dwon correct then add and tune the alky, 92 octane and 16ish on the boost, car has a large fmic and a tt chip with motron 60's, I have tried adding and subtracting fuel with little change, millivolts around 800 at wot and seems to knock very seldom when its not wot, also tried removing some low gear timing with little change as well, curious how one determines what is real and false knock?? Thanks for the help!! Ryan
