REAL power mirror for pass side 12v
BandAid
Keyboard Bully
I think its from a late 79ish to 83 vette, be the first on the block to have a real power mirror on the pass side..identical to the regal mirror...except power...:smile: $55.00 shipped no switch
are u sure the mounting base is cut at the same angle as the regal one, may be different because the shape of the door at that location was different, worth checking.
of course it will need to be painted,in the pics it looks different since it has studs poking out the bottom and i can set it even with my blue mirror,but it is the same mirror...mirror12.jpgmirror13.jpg
That looks different for sure, the housing is longer and the base has a different angle on the leading edge, studs or no studs.
OK ,just came back in from the nice cold garage ,thank you....:D with tape measure in hand,no paper and pencil tho....the mirror head is 100% identical to the GN/regal....the BASE however on the right side is 1/2" longer then a GN's
and on the left side of the BASE it is close to the same,or maybe 3/8"
BUT no fear as if you own a mirror on the passenger side already,and a Torx tool,just undo the 2 scres and swap base's
IN one of the pics it looks like one mirror is MUCH larger than the other,well thats not the case,just an illusion..
Ill take it if he passses I need it for a kit car Im building.
TRans Damm,are you in or out....your pm box is full....am i moving to the next in line...
