Realigning compressor housing HELP!
prrfectlaunch86
Trying to install my new te-44 today and I already have the old turbo removed and i'm just about ready to install the 44. Did a test fit with the new turbo and it fits fine but the compressor housing needs to be adjusted down about 5 degrees (estimate) downwards to line up properly with the intercooler inlet. I'm not exactly sure which bolts to loosen in order to rotate and adjust the compressor houising. There aren't too many bolts too choose from so im guessing that it's the 6 bolts on the outside edge of the compressor housing (on the center section side) how do I go about doing this the proper way? i want to make sure i do it correctly so i don't ruin my new turbo before i even get to drive it. Any help would greatly be appreciated! thanks for your input.
Nick
Loosen all the bolts on the inside of the compressor housing and you should be able to bump it to desired position.
Its sealed with a oring IIRC
