B BlueT-Type Member Joined Mar 23, 2010 Jun 5, 2010 #1 Can you use the original prop valve or do you need to replace it with a Disc/Disc one?
I Instro84 USAF retired Joined Jul 17, 2005 Jun 5, 2010 #2 when i put ls1 camaro brakes on all 4 corners, i modified the prop valve per instructions from baer brake rear disc kit. works really well hth.
R Red Regal T Senior Member Joined May 24, 2001 Jun 5, 2010 #3 http://www.turbobuick.com/forums/2503073-post4.html
B BlueT-Type Member Joined Mar 23, 2010 Jun 21, 2010 #6 What is the Down side to not doing the Prop valve Mitifications and just leaving the stock one in place??
The_Six Active Member Joined Feb 28, 2009 Jun 21, 2010 #7 rear brakes can lock up before and harder then the front and cause the rear to come around on you in hard braking.
