C
coach
Guest
I'll measure them tomorrowMy word, should have know that with the skill set you have. How thick are they, what ga?
SignUp Now!I'll measure them tomorrowMy word, should have know that with the skill set you have. How thick are they, what ga?
Parts ordered. Thanks for the info.Yep...41( meaning 4130 steel) 112 ( meaning 1 1/2" diameter) and 065 ( meaning wall thickness of 0.065)
41-112-065
This should work for even a full on racecar.
The brkts are lasered out of 1/8" plate stock.
Got everything mounted, cut, and mocked up today. Now it just needs welding. FYI, I only needed ~49-1/2" of tubing to go from bracket to bracket. It clears the filler neck with plenty of room to spare. Here are some pics:
View attachment 222521 View attachment 222522 View attachment 222524 View attachment 222525
Did you add any gussets to the tubing on your brace?Looks just like mine!![]()
None needed. It's gonna do its job all by itself. The cars function without it...so adding it stops what flexing there is.Did you add any gussets to the tubing on your brace?
And it's done. Had it welded on the car and then powder coated black. Put the rear bumper on and took it for a drive. The car felt extremely 'tight' but I did install the 'GNX' brace at the same time so take that with a grain of salt. Here are some pics:
View attachment 224239 View attachment 224240 View attachment 224242
Fine with me.Looks Great! Can we use any of your guy's install pictures for our website?
