Rear license plate filler panel
NOKA72
hello guys. Tried to search but I’m not having any luck. I am replacing my fillers front and rear. 12k mile GN. so I’m looking for originality.
The rear license plate filler that goes in between the rear bumper fillers, that should be painted body color just as the bumper fillers. Correct? And the top is trim black to match the tail light bezels correct? Also any clue if that tape is from the factory???Thanks vinny
The advice that I can offer is to compare your factory headlight bezels to your "new" front bumper fillers. When looking at the bottom of your headlight bezel where the corner lamp is mounted, make sure that corner has the same shape as the one on your front filler. My uncle ordered some fillers off of ebay and its corner is more "rounded" than the headlight bezel. The lip that the filler has at the top pokes out under the headlight bezel. He found that out after getting them painted nice and glossy. My rear license plate filler is satin to match the trim on the tail light bezels.
Thanks. I went with the goodmark fillers as I hear they are very close. Just want to verify if I need to paint the filler behind the fuel door the same body color or not. Thanks VINNY
I believe that panel is left satin black on the non-GN Turbo Regals. So I doubt they painted them body color on the GNs.
