HighMileage
Albany,NY
- Jul 24, 2010
Got a new set of Metco lower arms today. I'm gonna attempt to put them on tomorrow.
Are there any tips or important things to check while I'm under there?
Here are the instructions,edited for length:
Support rear of car with stands ahead of front mounting hole.
Removing wheels/tires is recommended for access.
Place jack under rear end. Raise to half travel.
Remove Swaybar bolts from one side.
Remove bolts that secure control arm. (remove/replace one side at a time)
Snug bolts,do not tighten at this time.
Once both arms are installed,jack up rear so that all weight is on suspension.
Torque to 75lbs.
Grease with Teflon poly lube or chassis grease. (I have Red-n-Tacky Lucas)
Thanks!
Torque to 75lbs.
Thanks!
