Hey guy's,
I have a leak threw the rear window.
It is coming in thru somewhere and then out thru the plastic cover holding up the head liner. The weather stripping on the rear is fine. I was wondering if there is some sort of way to adjust the hinges on the window to cause it to put more pressure on the weather stripping?
Or if any of you have had this problem and have a way to fix it. I will take some pic's and post them in a little bit.
