Rear window removal
It's glued in.
Disconnect the defroster if there is one. it's connected to body ground in the passenger side sail panel.
Then you have to get a special knife to cut the old adhesive.
Al's right. You can also use a fine piece of wire if you can get it under the window but you'll need 2 people to do it.
So why are you wanting it out. The factory and dealers of the time used Butyl adhesive on the windows. It drys out and leaks. A modern urethane is much better for reinstalling it.
You need two people! Go get a fein tool with a long blade(or go to hrbor frieght) and cut the seal with it. Get your helper to hold a spackle knife(out side so you dont chip the paint) while you cut it from inside the car.You will also have to work it with a long flexable knife.These old seal leaks and you will see some rust behind the glass! Good Luck! Use caution around the bottom or you will mess up the rear deck
Removing the glass for rust repair that is right below this area.
