rear window with defogger and harness attached
Stage 5
Tx Dark Blue T
I need a great condition rear window with defogger. I also want the harness that goes from the window to the fuse box uncut and still attached to the window if possible, I believe it is a purple wire. I also want the ground wire still attached to the passenger side of the window. If any one is parting a car out with the defogger option let me know. I would like it shipped to 76035.
It includes the wiring also right so I can just plug it up to the connector at the fuse box and go?
yes sir. there should already be a purple wire there that un plugs. it is just a lead.
Well it is for my brothers 87 gn that did not come with the option. He already has the defogger switch amd he plugged it in and it lights up with the headlights and even glows on when you push the on button. So the switch is the relay right.
i had to go look at gnttype.org but yes the switch is a timer/relay all in one.:rolleyes:
