Since the stock motor is out of breath around 4800-5000 rpm, I would stick with the stock gears.
To find out what the "best gear ratio" is, you should take it to the track, and see what RPM you pass the line at. From there, based on the combo, you calculate it backwards.
You will find that the stock ratio is very good, especially for a stock set-up, and if your trap RPM is too high, get a slightly bigger diameter tire on it.
Hope this helps.
