frank_ster
- Feb 16, 2013
few months ago my crank broke due to bad machining ( welded and ground flat with no chamfered corners )
I had a new block and crank freshly machined and put it all back together.
After getting it running the oil pressure is low, when hot it's down to about 8lbs at idle when it used to be 25-30 with the same 0w20 oil. On top of that I have the by pass blocked on my oil filter mount since 4 years . But now the oil filters are folding flat on them selves and blocking oil flow also.
It seems I have a large leak some where after the oil filter. Which is making the oil filter the restriction in the system,
I hope it's something stupid like the gasket between front cover and block.
But wondering if the machine shop messed up on something like the cam bearing.
I can pull the oil pan on my car with out taking the engine out , so I hope to have a look .
I m thinking about using a electric pump to pressurize the oil system and see if I can track down this leak.
I hope the main and rod bearings are fine. But dam when the crank was broken i had more oil pressure than I do now!
Has anyone ever run into this kind of thing before ?
