Rebuilt fwd 87 3.8 and low oil pressure
Its probably been 20 years ago...seems like I used a screwdriver and turned it sideways like a freeze plug and then hooked it and popped it out. Its just soft aluminum, so its easy to distort.
Did you look at my pictures from my other thread ? I had the flex plate break 3 times . So i lasercut a 3/8" thick one and drilled it to match the bob weight of the stock one .
This is the first test of it , think its a problem not being as flexy as the stock one ? I am thinking about bolting the torque converter to it on the block and checking with a dial indicator make sure its true and ill grind to compensate
I looked it over. Its a really neat swap you have done. I am not real sure on the flexyness of your new flywheel. I would think so long as it could give some without breaking, it should be fine.
