85 hotair motor for sale
20 bolt oil pan, block decked, std bore,std (polished) crank,line honed w/ arp main studs, rods resized w/ arp rod bolts, speed pro forged pistons & moly rings, 208/208 dur. 456/456 lift cam, comp lifters, double roller timing chain, clevite 77 bearings,H.V. oil pump w/60# spring installed, heads have new valve job,mild bowl blending,lt1 spings,port matched to felpro 1200 intake gasket,ported js manufacturing style intake(made myself) runners port matched to fel pro 1200 intake set as well,42# green stripe injectors,accu fab adjustable fuel pressure regulator,atr up pipe,stock headers (have been welded), stock turbo and TE-44 turbo included (both in good shape), all new parts!!! no corners were cut building this motor at all!!! has 0 miles!!! i installed but never started. i decided to do a twin turbo small block chevy motor for this car
this thing will be pulled out and be complete throttle body to pan, also have pics of machine work and shortblock assembled, and if picked up will pull any part you wish to prove this thing is what i say and never run!
asking $3850 + shipping or you are welcome to pickup at my house.
