Here's my O2s worth.
With technology ever evolving, combos tend to change as fast as you can change the channel with your tv remote. Here are some combos that I would tell people when I was a salesman for PTE. Now, I will assume that the car you are starting with has already had the spring cleaning done and is in tip top running condition. IE compression test showed matching numbers within 10% on all 6 cylinders and no fluid leaks. This would be for all '86-'87 Turbo Buicks.
12 Second recipe.
- Scanmaster 2.0 for 86-87 Turbo Buick, & 89 TTA $249.99
- Walbro F2000169 (340M replacement) fuel pump with install kit $99-$149.00
- Fuel pump Hot Wire kit $35.00 - $50.00
- Adjustable fuel pressure regulator $99.99 - $120.00
- Fuel press gauge 0-100psi (Autometer preferred) $39.99-$41.99
- Gauge mounting cup 2 1/16" or 2 5/8" $14.99
- 4ft -4 braided SS line $41.99
- 90* -4 AN female to -4 AN male fitting ($15.99 ea 2 needed) $31.98
- Boost gauge that reads at least to 30psi $39.99 - $50.00
- Single a-pillar mount gauge pod $25.00
- 93 octane custom burned street chip $80.00-$130.00
- 110+ octane custom burned race chip $85.00-$130.00
- RJC boost control valve $49.00
- RJC Power plate for stock plenum $59.00
- K&N passengers side valve cover breather $16.00
- K&N drivers side breather with aluminum fill neck $32.00 - $47.00
- K&N 9" cone filter $50.00
- MAF pipe $75.00 - $85.00
- Fuel filter $12.00
- O2 sensor $30.00
- Custom fit spark plug wires $40.00 - $60.00
- Spark plugs x6 AC 42s or Autolite 23s $12.00
- 160* thermostat $9.00
- Billet aluminum thermostat neck $25.00
- PCV check valve $20.00
- Engine tie down strap $37.00
- Heavy Duty valve springs 100# $40.00
- Heavy Duty rocker arm shafts with rockers $80.00
- Valve cover gaskets $15.00
- Double roller timing chain $120.00
- Torrington thrust button for cam $15.00
- Front cover gasket $15.00
- 3" Terry Houston style SS downpipe with test pipe $439.99
- Dual 2.5" exhaust system $330.00 - $579.00
- Driveshaft safety loop $35.00
- Eaton posi traction unit if car does not already have G80 code $429.00
- Rear end fluid $35.00
- Rear end cover gasket $12.00
- Remove trash screen from stock intercooler shroud $FREE$
- 26x8.5 MT slicks x2 $304.00 (best traction for stock rims)
- Dual rear coil spring air bags Air Lift 60733 $70.00
- Flip switch, wire, wire connectors for Torque Converter L/U switch $25.00
- Disconnect front sway bar at the drag strip for best weight transfer $FREE$
Now, this amount of parts is typically what it would take to have a reliable 12 second recipe. There are many who have run into the 12's with fewer parts, but eventually, every setup will have these parts on their car if they intend on going faster and reliably. With this setup, you will be able to tune for the octane and boost that you plan on running, adjust the boost and fuel pressure levels, as well as having custom burned chips for racing conditions. It is advised that if your stock injectors have high mileage (over 100K miles) that you either have them cleaned or replaced with larger injectors. Don't forget to have the chips matched to your injectors. The slicks will provide the best traction for a stock car with stock wheels. Obviously you can go with after market wheels and larger slicks or drag radials, however bang for the buck the 26x8.5 slicks are hard to beat.
11 Second recipe.
- Stock location air to air intercooler $700.00 - $900.00
- TE-44 to PT6152S Turbocharger $800.00 - $950.00
- MT 28x10.5 ET slicks $320.00
- Light weight aluminum wheels $650.00 - $800.00
- Lakewood 90/10 front drag shocks #40100 $88.00
- Driveshaft pinion snubber $23.00
- Kirbans front frame, under hood and rear seat braces $150.00
- 9" to 10" lockup or non lockup torque converter (match to turbo) $425.00 - $950.00
- B&M Supercooler transmission cooler kit $75.00 - $100.00
- Mototron 65# High Impedance injectors (set of 6) $330.00
- Accufab 70mm throttle body $250.00
- PTE 70mm Upper plenum Cast finish $140.00 or Polished $180.00
- RJC Power Plate for use with PTE plenum $59.00
- 3" straight nomex/silicone hose 4" long for use with new t-body $25.00
- 3" t-bolt clamp for new t-body $4.00
- Alcohol injection kit $530.00-$575.00
- Powerlogger Scantool or Direct Scan scantool $250.00
- Laptop computer for use with new scan tool $350.00-$900.00
- HR Parts & Stuff upper and lower rear control arms $475.00
Now, with these parts you will have the capability of running deep into the low 11's @ 118-122 mph with either pure C16 race gas or pump gas with alky. You will have the best traction and suspension pieces as well as full datalogging and tuning capabilities. You will have plenty of fuel injector to support more hp than the PT6152S turbo can provide and most aftermarket stock location intercoolers can support up to 800 fwhp. There are other things you can do to help lighten the car, IE fiberglass hood and bumpers, aluminum bumper brackets and skinny 15x3.5 front rims and tires. Ported iron heads or aluminum heads will also help as well as a good street camshaft, but these parts are not mandatory to reach low 11's. All of the parts listed in both combos are tried and proven. Again, some have gone faster with fewer parts but I feel that all of these parts work very well together to make for a reliable 12 or 11 second combo. Tuning is absolutely the most important aspect to any combo or recipe and you don't need a super huge 70 series turbo to reach 11.00s. Remember, detonation kills these motors and don't skimp on safety if you are running faster than 11.49. IE: 6 point roll bar, fire jacket and pants, racing harness belts, obviously a certified helmet, metal valve stems, c-clip eliminators and longer wheel studs are all required by NHRA at this level.
Hope some of this helps and sorry so long.
Patrick
