Recommendations for Turbo, Injectors and chip replacement?
tpaul
I'm currently rebuilding the motor in my 85 GN. I'm looking for recommendations for replacement turbo, injectors, and a chip. I may add a set of GN1 heads down the road, not sure yet! With the mods below would I gain anything from bigger turbo and injectors, or should I stick with what I have? Here's a list of current mods to drive train:
Motor will have mild cam upgrade when complete
Walbro 340 fuel pump w/ hotwire kit
Green stripe injectors
Adjustable fuel pres. reg.
Kenne Bell headers
Gutted cat
2 1/2 exhaust w/ Super Turbo mufflers
LT1 MAF w/ Translator
Big mouth cold air intake
Heated 02 sensor
Adjustable wastegate
87 Coil pack and Ignition module
87 ECM
2800 stall converter
Shift kit and upgraded clutch packs and servo - built by Jimmy's in Mundelein, IL
160 deg. therm.
Electric fan - no pulley fan
Thanks in advance for the input!
I'd do a bigger turbo. Ta-33 if you want an easy bolt on. Then you might end up wanting some bigger injectors at least 36# or bigger.
