red armstrong type volt booster
william B.
does anyone make a boost reference volt booster, plug and play like reds, looking for something that increases voltage around 30% tps, thats where i spend most of my boosted driving, thanks
Caspers Electronics is the only one left that's new and bumps volts that I can think of.
Or Powermaster XS alternator but that's not very stable and if you ever run a Lithium battery you better ditch that alt, not predictable at all.
there is alot of info on this site,I think one terminal on the voltage reg gets battery voltage thru a relay then connect a few resistors to the other side of the relay then use a hobbs switch totrigger the relay and send a false lower voltage to the reg under boost.
Theres a schematic for making one somewhere on gnttype. Its pretty easy to modify that one to be adjustable.
If you get the Caspers upgraded alt to battery wiring kit, you'll see real voltage from a good alternator and not really need all this. I'm 13.9-14.5v all the time and usually 14.2v often.
have a caspers now,seeing 14.6v at alt,batt,and fast touch screen at same time, turn ac and headlites on shows 14.0v at idle maybe would go less if i step on brakes,didnt check,when reved in park nothing on dropped from 14.6v to 14.1v when reved up to trigger tps 70% flashed 17v only held it there for split second to see if volt booster worked,
tried gnttype. lastnite and just now, get message that says server exceeded bandwidth, not working for me, thank you
